[postgis-devel] [PostGIS] #1009: lookup_tables_2010.sql - Index creation error
trac at osgeo.org
Thu Jun 9 08:49:38 PDT 2011
Reporter: egouge | Owner: robe
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: trunk
Keywords: |
Line 950 in tables/lookup_tables_2010.sql is creating an index on the
faces table which at this point doesn't exist.
CREATE INDEX tiger_state_the_geom_gist ON faces USING gist(the_geom);
should probably be:
CREATE INDEX tiger_state_the_geom_gist ON state USING gist(the_geom);
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1009>
