[postgis-devel] [PostGIS] #1005: [raster] Problem with ST_SummaryStats(text, text) results
trac at osgeo.org
Thu Jun 9 21:29:01 PDT 2011
Reporter: pracine | Owner: dustymugs
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by robe):
Pierre,
Okay I'm seeing similar behavior on PostgreSQL 9.1 for ST_SummaryStats and
ST_Histogram. So I think it has to do with if you materialize vs. not.
So here is a single tile raster I have with 1,517,411 pixels.
-- This takes 1,147ms --
SELECT (f).*
FROM (SELECT (ST_SummaryStats(rast,1)) As f
from philly_map) As foo;
--but this takes 214 ms
SELECT (f).*
from philly_map OFFSET 0) As foo;
NOTE in the second -- I used the OFFSET 0 hack to force materialization of
the subselect as described here --
http://www.postgresonline.com/journal/archives/113-How-to-force-
PostgreSQL-to-use-a-pre-calculated-value.html
-- The histogram case is tempermental if it materializes
-- or not since it is dependent on number of rows
-- Takes 294 ms returns 22 rows (with the offset takes 306ms -- so about
the same
SELECT (f).*
FROM (SELECT ST_Histogram(rast,1) As f
So I guess short answer -- if we are going to be doing wrapper stuff, we
better put in an OFFSET 0 in there just to be safe. Haven't tested on
8.4, but as I recall way back, its the same story.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1005#comment:17>
