[postgis-devel] [PostGIS] #989: [raster] gdal2wktraster.py has trouble with GRD files
trac at osgeo.org
Fri Jun 10 05:56:58 PDT 2011
Reporter: dondrake | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by etiennebr):
You're right, I got a warning with your file(I missed it on first time
because I was in verbose mode):
DeprecationWarning: integer argument expected, got float hexstr =
binascii.hexlify(struct.pack(fmt_little, data)).upper()
But I doubt it is linked to grd as
>gdal_translate test.grd test.tif
Input file size is 2334, 2467
Warning 1: Unable to export GeoTIFF file with different datatypes per
different bands. All bands should have the same types in TIFF.
0...10...20...30...40...50...60...70...80...90...100 - done.
and then same warning with raster2pgsql.py --raster=test.tif (even if it
switched band 4 type to byte)
Hope it can help you Pierre...
Etienne
Ticket URL: <http://trac.osgeo.org/postgis/ticket/989#comment:8>
