[postgis-devel] [PostGIS] #666: ST_DumpPoints is not null safe
PostGIS trac at osgeo.org
Fri Jun 10 10:08:52 PDT 2011
  Reporter:  robe     |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 1.5.3
 Component:  postgis  |     Version:  1.5.X
Resolution:  fixed    |    Keywords:  history
Changes (by robe):
  * keywords:  => history
  * status:  new => closed
  * resolution:  => fixed
Old description:
> SELECT ST_DumpPoints(foo1.the_geom)
>         FROM ((SELECT CAST(Null As geometry) As the_geom)) As foo1;
> Gives error -
> ERROR:  Unexpected error while dumping geometry <NULL>
> CONTEXT:  SQL function "st_dumppoints" statement 1
New description:
 Gives error -
Comment:
 Fixed at r7360 for 1.5 and r7361 for PostGIS 2.0.0.  Note the
 _ST_DumpPoints still has an issue thought no one would be calling that
 directly.  Can't make that strict since it should have nulls passed in.
 For a more permanent solution - we might want to just go with yabo's
 suggestion.
 With my fix, dumping a NULL will return no records which is hmm okay with
 me.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/666#comment:5>
