[postgis-devel] [PostGIS] #925: [raster] ST_Transform
PostGIS trac at osgeo.org
Fri Jun 10 13:57:09 PDT 2011
 Reporter:  dustymugs       |       Owner:  dustymugs
     Type:  task            |      Status:  assigned
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:  history         |
Comment(by robe):
 Well I'm not getting the error anymore abot libproj-0.dll, but I get check
 failed
 line 1490.
 Check failed on line 1490
 make[2]: *** [check] Error 1
 make[2]: Leaving directory `/c/projects/PostGIS/trunk/raster/test/core'
 make[1]: *** [core-check] Error 2
 make[1]: Leaving directory `/c/projects/PostGIS/trunk/raster/test'
 make: *** [core-check] Error 2
 and still get the wrong answers in postgresql.  Pierre -- are you answers
 right in PostgreSQL?  If you just run the regress tests in an installed
 raster db?
 As far as the proj thing given that it seems to default to libproj-0.dll
 or some such thing, which I recall is the name I get when I compile proj
 4.7.1, it might not be that bad.
 I was thinking of releasing PostGIS 2.0 with proj 4.7 anyway, but wanted
 to verify it didn't break things -- which as I said I'm having some issues
 with my linux box installed with prj 4.7 not being able to reproject
 things which is part reason I can't use my Linux box for production work.
 But that's neither here nor their, but I guess testing on 4.7 on windows
 will rule out issue only on linux with proj differences.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/925#comment:48>
