[postgis-devel] [PostGIS] #1014: GEOMETRY type is not "hashable"
trac at osgeo.org
Wed Jun 15 00:24:28 PDT 2011
Reporter: vince | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 1.5.3
Component: postgis | Version: 1.5.X
Resolution: wontfix | Keywords: GEOMETRY hash UNION
Comment(by mcayland):
It seems there is an explicit check for zero added into the floating point
hash function. However, in the case of PostGIS we'd have to take a copy of
the geometry, isolate the floating point numbers within it, fix the zero
values, hash it and destroy the copy. That's quite a lot of tricky work to
do in order to make this work.
If someone can show that making geometry hashable is a big win then I
would consider a patch, but it's going to need a fair bit of work.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1014#comment:6>
