[postgis-devel] [PostGIS] #1029: geometric object crashes server with Out Of Memory
trac at osgeo.org
Thu Jun 16 06:45:02 PDT 2011
Reporter: cousinm | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.3
Component: postgis | Version: 1.5.X
Keywords: |
The attached object crashes the PostgreSQL server after allocating more
than 20 Gigabytes of ram (sometimes bringing the server with it), when
using any GIS function even st_isvalid().
I don't know if it is valid, it was provided «as is» by a user, and I
can't run st_isvalid() on it.
SELECT postgis_full_version();
POSTGIS="1.5.2" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.7.1, 23 September
2009" LIBXML="2.7.8" USE_STATS
(1 row)
The attached script creates a «test» table, and puts this object inside
it.
Please tell me if I can provide anything to help on this problem.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1029>
