[postgis-devel] [postgis-users] 1.5.3rc1
Paul Ramsey pramsey at opengeo.org
Fri Jun 17 11:58:45 PDT 2011
Also builds and regresses against 9.1b2
On Fri, Jun 17, 2011 at 11:54 AM, Paul Ramsey <pramsey at opengeo.org> wrote:
> Also passes against 8.3 on OSX. Release in t-minus 24 hours if radio
> silence holds.
> P
> On Thu, Jun 16, 2011 at 11:27 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> UPDATE - regression passes on our 8.3.15 Mingw install -- we were just
>> missing the libconv-2 dependency in last tests.
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paragon
>> Corporation
>> Sent: Friday, June 17, 2011 12:02 AM
>> To: 'PostGIS Development Discussion'
>> Cc: 'PostGIS Users Discussion'
>> Subject: Re: [postgis-users] [postgis-devel] 1.5.3rc1
>> Okay we tested with the tar ball.  Tar ball looks good.
>> Works on our windows dev box against
>> PostgreSQL 8.4.7, PostgreSQL 9.0.2 VC++ builds
>> And regress tests pass
>> However we are having a  battle getting the postgresql tests to pass on
>> PostgreSQL 8.3.  I think this has more to do with the way Iwe are testing
>> and some path setting we are missing than anything wrong with the packaging.
>> For 8.4, 9.0 we are testing against the Enterprise Db VC++ builds, however
>> the 8.3 Enterprise Db builds are no longer available on the site, and we
>> have long since uninstalled that version from all our servers.
>> Anyrate the 8.3 postgis-1.5.dll  builds, we just can't really test it at the
>> moment and looking at the dependency doesn't give a clue as to what is
>> missing.
>> ----- TO WINDOWS USERS ---
>> We'll put up the binaries in the next day or so for all 3, and if anyone
>> with a PostgreSQL 8.3 install can confirm the binaries work okay, that would
>> be great
>> One other question and this is more of a question to Windows users:
>> Does anyone mind if we package geos-3.3.0 instead of geos-3.2.2?
>> Normally we package the latest minor of whatever release, but this poses
>> problems if you have multiple PostGIS versions on the same PostgreSQL
>> service in different databases.
>> So if you are running PostGIS 1.5 or 1.4 and you are also running PostGIS
>> 2.0 (development or final when it comes out),
>> 1) The PostGIS 1.5 upgrade or PostGIS 1.4 upgrade would break your existing
>> PostGIS 2.0 since they share the same GEOS and the newer PostGIS would cough
>> up at an older GEOS.
>> 2) The other reason is that non-critical performance only fixes are rarely
>> backported to older GEOS.  So for example improvements in topological errors
>> etc. you would miss out with a GEOS 3.2.
>> The only reason to package a geos-3.2 instead of geos-3.3 is since there is
>> less change, there is less chance of things like speed differences minor
>> output differences adversely affecting you.
>> Thanks,
>> Regina and Leo
>> http://www.postgis.us
>> From: postgis-devel-bounces at postgis.refractions.net
>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
>> Ramsey
>> Sent: Thursday, June 16, 2011 1:53 PM
>> To: PostGIS Development Discussion
>> Subject: [postgis-devel] 1.5.3rc1
>> Tagged
>> http://svn.osgeo.org/postgis/tags/1.5.3rc1
>> and bagged
>> http://postgis.org/download/postgis-1.5.3rc1.tar.gz
>> P.
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
