[postgis-devel] [PostGIS] #894: _ST_Expand for geography is broken
trac at osgeo.org
Fri Jun 17 12:12:39 PDT 2011
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.5.X
Keywords: |
Comment(by pramsey):
Can you re-confirm? I get 'true' in PostGIS 2.0 for all your examples.
Regards the first point, that expanding doesn't change the geometry, you
are right, that it is the box being expanded, not the geography. More to
the point, it's not possible to represent the box as a geography. The box
is a 3d geocentric box. The geography is a set of 2d spherical
coordinates. So expand grows the cached box but doesn't alter the
coordinates of the object. This is why it's _ST_Expand(), because there's
no way a user is ever going to grok the subtlety.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/894#comment:2>
