[postgis-devel] [PostGIS] #520: No check for different srid on operators when index is used
trac at osgeo.org
Sat Jun 18 23:17:13 PDT 2011
Reporter: nicklas | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
FWIW, I really don't think this is a big issue and would just assume
forget about it if its hard to fix. Usually when people use &&, they know
what they are doing and I suspect trying to fix this will just slow things
down.
NOTE: This more common query does give error:
SELECT a.gid As a_gid, b.gid As a_gid, ST_SRID(a.geom) As a_srid,
ST_SRID(b.geom) As b_srid
FROM tb1 As a, tb1 As b
WHERE ST_Intersects(a.geom,b.geom);
ERROR: Operation on mixed SRID geometries
Ticket URL: <http://trac.osgeo.org/postgis/ticket/520#comment:9>
