[postgis-devel] [PostGIS] #1017: Implement topology.ToTopoGeom(Geometry, topology_name, layer_id)
PostGIS trac at osgeo.org
Sat Jun 18 23:22:24 PDT 2011
 Reporter:  strk      |       Owner:  strk
     Type:  task      |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by aperi2007):
 I guess this function should have also a parameter "tolerance",
 because when you add , for example, a line to an existent topology,
 it could be need add only some segments of that line because other
 segments there is available in the topology.
 So you could use the CommonShared and ST_Snap to understand what is really
 needed to add to the topology of the new geometry.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1017#comment:1>
