[postgis-devel] [PostGIS] #1037: geography: ST_Intersects, ST_DWithin gbox_overlaps: geometries have mismatched dimensionality
trac at osgeo.org
Mon Jun 20 00:43:54 PDT 2011
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.4
Component: postgis | Version: 1.5.X
Keywords: |
Old description:
> Paul,
> Can you take a look at the attached query and let me know if it errors
> out for you. I'm getting a lot of these errors with my California
> geometries when experimenting with geography.
> This fails on 1.5.2, 1.5.3 rc1, and 2.0.0 trunk.
> This particular polygon has 380 points (smallish in myset). I've tried
> with smaller polygons and don't have the issue so not sure if its a
> number of points issue or not. I've got some polygons with over 20,000
> points also failing. This is on a Windows 2008 R2 (64-bit running 32-bit
> PostgreSQL/PostGIS in case that matters).
New description:
Paul,
Can you take a look at the attached query and let me know if it errors out
for you. I'm getting a lot of these errors with my California geometries
This query gives a: ERROR: gbox_overlaps: geometries have mismatched
dimensionality error.
with smaller polygons and don't have the issue so not sure if its a number
of points issue or not. I've got some polygons with over 20,000 points
Comment(by robe):
This could be related to bug #261 that you fixed.
You did say their might be other cases like this lurking in the code.
FWIW:
ST_Distance, ST_DWithin, ST_Intersects calls for these 2 geometries also
gives the
ERROR: gbox_overlaps: geometries have mismatched dimensionality
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1037#comment:1>
