[postgis-devel] [PostGIS] #1038: SVG empty geometries gives invalid memory alloc
PostGIS trac at osgeo.org
Mon Jun 20 01:51:31 PDT 2011
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 This is doing regression between our current 1.5.3 and 2.0.0.  I haven't
 tested our older 2.0.0 yet to see if it was introduced during change to
 gserialize.
 This fails in current 2.0.0 trunk but just returns an empty string in 1.5.
  SELECT ST_AsSVG(foo1.the_geom) As result
                                                         FROM ((SELECT
 ST_GeomFromText('GEOMETRYCOLLECTION EMPTY',4326) As the_geom
                         UNION ALL SELECT ST_GeomFromText('LINESTRING
                         UNION ALL SELECT ST_GeomFromText('POINT
 EMPTY',4326) As the_geom ) ) As foo1 LIMIT 3;
 error:
 ERROR:  invalid memory alloc request size 4294967294
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1038>
