[postgis-devel] [PostGIS] #1040: ST_MinimumBoundingCircle using deprecated function X
PostGIS trac at osgeo.org
Mon Jun 20 02:05:48 PDT 2011
 Reporter:  robe     |       Owner:  robe
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
  SELECT ST_MinimumBoundingCircle(foo1.the_geom, 3) As result
                                                         FROM ((SELECT geom
 As the_geom
 FROM (VALUES ( ST_GeomFromEWKT('SRID=4326;POLYGONM((-71.1319 42.2503
 1,-71.132 42.2502 3,-71.1323 42.2504 -2,-71.1322 42.2505 1,-71.1319
 42.2503 0))') ),
         ( ST_GeomFromEWKT('SRID=4326;POLYGONM((-71.1319 42.2512 0,-71.1318
 42.2511 20,-71.1317 42.2511 -20,-71.1317 42.251 5,-71.1317 42.2509
 4,-71.132 42.2511 6,-71.1319 42.2512 30))') ) ) As g(geom))) As foo1 LIMIT
 3;
 Yields:
 function x(geometry) does not exist
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1040>
