[postgis-devel] [PostGIS] #746: ST_Dump with GSerialized POINT EMPTY and EWKT/AsText mismatch?
trac at osgeo.org
Mon Jun 20 14:03:36 PDT 2011
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by pramsey):
A deeper question is what the right answer to the ST_Dump() question is.
Try the following:
SELECT ST_Dump(ST_GeomFromText('POINT EMPTY',4326));
SELECT ST_Dump(ST_GeomFromText('LINESTRING EMPTY',4326));
SELECT ST_Dump(ST_GeomFromText('MULTILINESTRING EMPTY',4326));
SELECT ST_Dump(ST_GeomFromText('GEOMETRYCOLLECTION EMPTY',4326));
Try the final one in PostGIS 1.5 too. That seems to indicate the "right"
answer for ST_Dump(empty) is "no records".
Ticket URL: <http://trac.osgeo.org/postgis/ticket/746#comment:4>
