[postgis-devel] [PostGIS] #1043: ST_ValueCount proto returns integer instead of bigint
PostGIS trac at osgeo.org
Mon Jun 20 18:59:26 PDT 2011
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  low             |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Description changed by robe:
Old description:
> st_valuecount(rast raster, nband integer, exclude_nodata_value boolean,
> searchvalue double precision, roundto double precision DEFAULT 0)
> others returns big int
New description:
 also all the record based protos seem to return integer instead of bigint
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1043#comment:1>
