[postgis-devel] [PostGIS] #1046: Invalid geography polygons: BOOM! Could not generate outside point!
trac at osgeo.org
Tue Jun 21 02:50:02 PDT 2011
Reporter: mwtoews | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: 1.5.X
Keywords: geography boom |
I've seen a few "BOOM" errors over the past few months (e.g.,
[http://comments.gmane.org/gmane.comp.gis.postgis/27073
1][http://gis.stackexchange.com/questions/9217/postgis-certain-
multipolygons-cause-boom-could-not-generate-outside-point 2]). For
example, with PostGIS SVN r7443:
SELECT ST_Intersects('POINT(160 43)'::geography, 'POLYGON((0 0, 0 90, 180
90, 180 0, 0 0))'::geography);
SELECT ST_Area('POLYGON((0 0, 0 90, 180 90, 180 0, 0 0))'::geography);
The error comes from
[http://trac.osgeo.org/postgis/browser/trunk/liblwgeom/lwgeodetic.c#L1346
liblwgeom/lwgeodetic.c], with the famous last words [comments] "This
should never happen".
Note, the above geography polygon does not make any sense to the
[http://www.gcmap.com/mapui?P=W0+N0-W0+N90-W180+N90-W180+N0-W0+N0&DU=m
Great Circle Mapper]. I can think up many more invalid geography polygons
that produce the same "BOOM" error.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1046>
