[postgis-devel] [PostGIS] #1047: [raster] St_Reclass documentation should better explain bracket and parenthesis syntax
trac at osgeo.org
Tue Jun 21 08:27:49 PDT 2011
parenthesis syntax
Reporter: pracine | Owner: pracine
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by robe):
Pierre,
Can you provide a description of what you think it should say. NOTE: the
more detailed description of reclass args I put in the reclassarg type
description which is linked from ST_Reclass.
http://www.postgis.org/documentation/manual-svn/reclassarg.html
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1047#comment:1>
