[postgis-devel] [PostGIS] #1054: ZM mixup (ST_Summary giving screwy answers)
PostGIS trac at osgeo.org
Wed Jun 22 16:33:24 PDT 2011
 Reporter:  robe      |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  PostGIS 2.0.0
Component:  postgis   |     Version:  trunk
 Keywords:            |
 Paul,
 I was about to do #649 and while I was at it change to use new SQL/MM
 proper syntax when I noticed ST_Summary is giving what I consider the
 wrong answers.
 SELECT ST_Summary(ST_GeomFromEWKT('LINESTRING Z(0 0 1, 1 1 1)'));
 yields:
 LineString[M] with 2 points
 huh -- where is my M?
 Same issue with:
 SELECT ST_Summary(ST_GeomFromEWKT('POLYGON Z((0 0 1, 1 1 2, 1 2 3, 1 1 1,
 0 0 1))'));
 same answer with:
 SELECT ST_Summary(ST_GeomFromEWKT('POLYGON((0 0 1, 1 1 2, 1 2 3, 1 1 1, 0
 0 1))'))
 I get:
 Polygon[ZM] with 1 rings
    ring 0 has 5 points
 Note: this is different form what we have documented. I never did know
 what that B meant though.
 Also note that Mike Toews output has changed as well - refer to #649
 His now gives this:
 SELECT st_summary('SRID=4326;MULTILINESTRING((0 0 0 0, 1 1 1 1),
 (2 2 2 2, 3 3 3 3))');
   MultiLineString[ZB] with 2 elements
 strk -- can you let me know what to put for these bracket flags and
 confirm what they should be returning?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1054>
