[postgis-devel] [PostGIS] #944: typmod support for PostGIS geometry
trac at osgeo.org
Thu Jun 23 04:14:06 PDT 2011
Reporter: robe | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
Okay I committed the change I discussed abovee at r7450
There is one issue that is bugging me. That is our new types do not
display in a backwards compatible way. As far as speed goes, I have to
test more, but in a database of 30 geometry columns most of which wer
defined using contraints, the speed to output geometry_columns_v was under
23ms. I'll do a more straineous test of generating thousands of tables.
Getting back to what concerns me -- here is my basic test:
CREATE TABLE test_geom_typmod(gid serial primary key, geom
geometry(POINTZ,26986));
CREATE TABLE test_geom_constraint(gid serial primary key);
SELECT AddGeometryColumn
('public','test_geom_constraint','geom',26986,'POINT',3);
('public','test_geom_constraint','geomm',26986,'POINTM',3);
ALTER TABLE test_geom_typmod ADD COLUMN geomm geometry(POINTM,26986);
CREATE OR REPLACE VIEW vw_test_geom_typmod AS SELECT * FROM
test_geom_typmod;
CREATE OR REPLACE VIEW vw_test_geom_constraint AS SELECT * FROM
test_geom_constraint;
CREATE OR REPLACE VIEW vw_test_geom_constraint_cast AS
SELECT gid, geom::geometry(POINTZ,26986) As geom,
geomm::geometry(POINTM,26986) As geomm
FROM test_geom_constraint;
Of which the results of my query:
SELECT f_table_schema, f_table_name, f_geometry_column, coord_dimension,
srid, type
FROM geometry_columns_v WHERE f_table_schema = 'public';
yield:
f_table_name | f_geometry_column | coord_dimension | srid
| type
raster_columns | extent | 2 |
0 | Geometry
test_geom_constraint | geom | 3 |
26986 | POINT
test_geom_constraint | geomm | 3 |
26986 | POINTM
test_geom_typmod | geom | 3 |
26986 | PointZ
test_geom_typmod | geomm | 3 |
26986 | PointM
vw_test_geom_typmod | geom | 3 |
26986 | PointZ
vw_test_geom_typmod | geomm | 3 |
26986 | PointM
vw_test_geom_constraint | geom | 2 |
0 | Geometry
vw_test_geom_constraint | geomm | 2 |
0 | Geometry
vw_test_geom_constraint_cast | geom | 3 |
26986 | PointZ
vw_test_geom_constraint_cast | geomm | 3 |
26986 | PointM
I fear this change in casing will break applications. I can almost
forgive the difference between PointZ and POINT since most tools we work
with are currently 2D anyway.
The other change I made is I cast all the columns so the are the same type
and size as teh original geometry_columns. Before they were outputting
objects of type "name" which I can just see a bunch of things coughing up
on.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/944#comment:31>
