[postgis-devel] [PostGIS] #884: Unstable results with ST_Within, ST_Intersects
trac at osgeo.org
Thu Jun 23 16:51:03 PDT 2011
Reporter: strk | Owner: chodgson
Type: defect | Status: closed
Priority: high | Milestone: PostGIS 1.5.3
Component: postgis | Version: 1.5.X
Resolution: fixed | Keywords: history
Changes (by chodgson):
* status: reopened => closed
* resolution: => fixed
Comment:
My previous bug fix failed to test polygons after the first one due to
using continue and skipping over the index incrementing. This is now
corrected in r7460 (1.5) and r7461 (trunk/2.0).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/884#comment:25>
