[postgis-devel] [PostGIS] #712: ST_IsValidDetail and ST_IsValidReason POLYGON CRASH
trac at osgeo.org
Sun Jun 26 10:28:46 PDT 2011
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by pramsey):
It looks pretty easy if one knows what the form of a GEOS empty polygon
is. In the case of LWGEOM, it's coming in with nrings == 0 and **rings ==
NULL, so it crashes when it tries to dereference rings[0]. Instead of de-
referencing it should be checking for nrings == 0 and in that case
constructing an empty polygon.
It looks like both the LINESTRING and POINT cases work because they are
going in with a non-null POINTARRAY that has npoints == 0 and
*serialized_ptlist == NULL. So the GEOS interpretation of "empty" is
working in those cases. Any help you can provide, appreciated.
For GEOS 3.3 you've provided nice easy createEmpty signatures, but what
happened for pre-3.3? We did pass in empty geometry collections, right?
I've got GEOS 3.2 and it's handling every other empty just fine.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/712#comment:3>
