[postgis-devel] [PostGIS] #1064: [raster] transform regress failing on 8.4 windows build
trac at osgeo.org
Mon Jun 27 06:10:58 PDT 2011
Reporter: robe | Owner: dustymugs
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Changes (by dustymugs):
* owner: pracine => dustymugs
* priority: medium => blocker
* status: new => assigned
Comment:
Based upon your regression results, that one test is failing as the SRS
isn't getting imported. I had this creep up and suspect there is a memory
issue (overflow?) going on.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1064#comment:1>
