[postgis-devel] [PostGIS] #520: No check for different srid on operators when index is used
trac at osgeo.org
Tue Jun 28 12:10:02 PDT 2011
Reporter: nicklas | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords: history
Changes (by nicklas):
* keywords: => history
* status: new => closed
* resolution: => fixed
Comment:
Hallo
I think Paul is right. The srid check is not there in the gserialized
versions of the box comparing functions in file gserialized_gist_2d.c
If I test the query in Pauls example above it passes in trunk version but
gets caught in 1.5.
I think this is the right behavior.
Regina, when I tried your example it also passed in trunk both with and
without index.
So I close this one.
I also put a history tag for slightly new behavior.
Thanks
Nicklas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/520#comment:11>
