[postgis-devel] [PostGIS] #1076: County Roads and Highways
trac at osgeo.org
Tue Jun 28 14:23:01 PDT 2011
Reporter: mikepease | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: 1.5.X
Keywords: |
County Roads and Highways that are referred to by number seem to confuse
the geocoder.
--This well-formed county road address doesn't geocode to the correct
location[[BR]]
select (addy).*,*
from geocode('16725 Co Rd 24, Plymouth, MN 55447')
--Spelled out in long form also gets an incorrect location[[BR]]
select (addy).*,*
from geocode('16725 County Road 24, Plymouth, MN 55447')
--But it works when you put in just the number of the road without saying
county road[[BR]]
select (addy).*,*
from geocode('16725 24, Plymouth, MN 55447')
--Also works when referring to the same road by name[[BR]]
select (addy).*,*
from geocode('16725 Rockford Road, Plymouth, MN 55447')
--Similar example for County Highway (doesn't work)[[BR]]
select (addy).*,*
from geocode('13800 County Hwy 9, Andover, MN 55304')
--Works with just the number of the hwy[[BR]]
select (addy).*,*
from geocode('13800 9, Andover, MN 55304')
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1076>
