[postgis-devel] [PostGIS] #1076: County Roads and Highways
trac at osgeo.org
Tue Jun 28 14:39:13 PDT 2011
Reporter: mikepease | Owner: robe
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.0
Component: tiger geocoder | Version: 1.5.X
Keywords: |
Comment(by mikepease):
Thanks for working so quickly on these issues! I hope to start using this
geocoder for my project work when the bugs are pretty well worked out.
You may already know this, but I found this error also applies to State
and US Highways. Probably also Interstates, but I didn't find an example
of that yet.
--US Highway doesn't work
select (addy).*,*
from geocode('3859 Highway 61 W, Red Wing, MN 55066')
--works with just number
select (addy).*,*
--state hiway doesn't work
select (addy).*,*
from geocode('2901 Highway 13 W, Burnsville, MN 55337')
select (addy).*,*
from geocode('2901 13, Burnsville, MN 55337')
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1076#comment:3>
