[postgis-devel] [PostGIS] #1058: [raster] Two-raster spatial operations framework proposal
    trac at osgeo.org
    Tue Jun 28 20:02:05 PDT 2011
 Reporter:  bnordgren       |       Owner:  pracine
     Type:  enhancement     |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  1.5.X
 Keywords:                  |
Comment(by bnordgren):
 Ok, this is what I get for opening my mouth.
 It appears to be more complicated than I thought at first blush (or so
 says the compiler). The bit I need to depend on is the proj4 cache api.
 This part connects to the database to get the proj4 string from the
 spatial_ref_sys table. Whoops. It also depends rather heavily on the
 postgresql memory context. Whoops. Whoops.
 Moving this code to liblwgeom would create a dependency from liblwgeom to
 the core postgresql libraries, and would probably make us compile
 liblwgeom as a postgresql module, if I understand this pgxs thing
 right.... I need to reconfirm with you that this is actually what you want
 to do before I up and do it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1058#comment:6>
