[postgis-devel] [PostGIS] #1077: Regression tests for tiger geocoder
trac at osgeo.org
Tue Jun 28 20:07:46 PDT 2011
Reporter: robe | Owner: robe
Type: task | Status: new
Priority: high | Milestone: PostGIS Future
Component: tiger geocoder | Version: 1.5.X
Keywords: |
Now that we are making so many changes to tiger geocoder I fair breaking
things. Thus need to start writing up regression tests.
Normalize_address is easy since most of what is needed for normalize can
run with just raw tiger data loaded.
Geocode is harder since it needs real data so we might have to setup
samples.
Speed is important since any minor change we make can significantly impact
speed, and that is even trickier to regress since its so dependent on
database setup.
Anyrate we'll just start setting up tests and hand test them as we make
changes until we've got a better idea.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1077>
