[postgis-devel] [PostGIS] #944: typmod support for PostGIS geometry
trac at osgeo.org
Thu Jun 30 11:25:11 PDT 2011
Reporter: robe | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by pramsey):
Sorry to revisit this, but I just noticed (duh) that geometry_columns as a
``coord_dimension`` column which partially removes the need for the
``type`` column to include dimensionality signifiers like ZM. So we could
retain (backwards compatible) ZM-less uppercase types. Unfortunately
there is another side to this which says that the ``coord_dimension`` only
gives number of ordinates, but doesn't distinguish between XYZ and XYM.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/944#comment:39>
