[postgis-devel] [PostGIS] #1066: [raster] raster crashes server with arbitrary tests
PostGIS trac at osgeo.org
Thu Jun 30 17:21:11 PDT 2011
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  critical        |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by dustymugs):
 I just ran the attached crash_raster test on 8.4.8 with postgis r7530 and
 did not experience a crash.  I did notice that the calls to ST_Quantile
 contain invalid values for the quantile parameter (value needs to be a
 percentage so between 0 and 1).
 I'll test also on 9.0 as well as through valgrind to hunt down memory
 leaks.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1066#comment:2>
