[postgis-devel] geocoder rev 7531
Paragon Corporation
lr at pcorp.us
Thu Jun 30 23:19:30 PDT 2011
Brian,
Does your log show anything? I just revised to force Unix line breaks and
also got rid of the CREATE index call at the end which might have been
causing problems.
Unfortunately not near a Linux machine at moment so can't test.
You can also remark out the line that reruns the tiger_loader.sql .. I
haven't changed that in a while.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of
maplabs at light42.com
Sent: Friday, July 01, 2011 12:13 AM
To: postgis-devel at postgis.refractions.net
Subject: [postgis-devel] geocoder rev 7531
upgrade_geocode.sql hung .. idle in transaction... ??
psql (9.0.4)
POSTGIS="1.5.2" GEOS="3.3.0-CAPI-1.7.0" PROJ="Rel. 4.7.1, 23 September
2009" LIBXML="2.7.6" USE_STATS
/home/shared/srcs_ras/postgis_trunk/extras/tiger_geocoder/tiger_2010$
psql geocoder -f tiger_loader.sql
SET
BEGIN
DROP AGGREGATE
CREATE AGGREGATE
CREATE FUNCTION
DROP TABLE
psql:tiger_loader.sql:38: NOTICE: CREATE TABLE / PRIMARY KEY will create
implicit index "loader_platform_pkey" for table "loader_platform"
CREATE TABLE
INSERT 0 1
INSERT 0 1
DROP TABLE
psql:tiger_loader.sql:92: NOTICE: CREATE TABLE / PRIMARY KEY will create
implicit index "loader_variables_pkey" for table "loader_variables"
CREATE TABLE
INSERT 0 1
DROP TABLE
psql:tiger_loader.sql:105: NOTICE: CREATE TABLE / PRIMARY KEY will create
implicit index "loader_lookuptables_pkey" for table "loader_lookuptables"
CREATE TABLE
COMMENT
COMMENT
COMMENT
COMMENT
INSERT 0 1
INSERT 0 1
INSERT 0 1
INSERT 0 1
INSERT 0 1
INSERT 0 1
INSERT 0 1
INSERT 0 1
INSERT 0 1
CREATE FUNCTION
CREATE FUNCTION
CREATE FUNCTION
COMMIT
dbb at ra-server:/home/shared/srcs_ras/postgis_trunk/extras/tiger_geocoder/tige
r_2010$ psql geocoder -f upgrade_geocode.sql SET
>>>>>> does not complete...
postgis-devel mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-devel
