[postgis-devel] [PostGIS] #852: The use of tolerance in function point_in_ring is not robust.
PostGIS trac at osgeo.org
Fri Mar 4 15:18:56 PST 2011
 Reporter:  nicklas  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
Description changed by nicklas:
Old description:
> I have taken a closer look at function point_in_ring because of my task
> in #846.
> There is two independent problems.
> the row numbers references the file lwgeom_functions_analytic.c
> 1) on line 1133 we find this
>         /* a point on the boundary of a ring is not contained. */
>                 if (fabs(side) < 1e-12)
> the problem here is that the calculated values "side" is not only related
> to the distance between the point and the segment but also to the length
> of the segment. That results in that the first example here returns false
> and the second true even if the point is on the exact same distance from
> the polygon in both cases.
> select st_intersects('POINT(5 0.5000000000001)'::geometry,'POLYGON((0 0,
> 10 10, 1 0, 0 0))'::geometry);
> select st_intersects('POINT(0.5 0.500000000001)'::geometry, 'POLYGON((0
> 0, 1 1, 1 0, 0 0))'::geometry);
> 2) the second problem is the construct to first check on which side of
> the segment the point is with a tolerance and then deciding if the point
> is within the endpoints without a tolerance. The second test will make
> the tolerance worthless if the segment is vertical or horizontal. That is
> actually the reason why the bug #845 showed.
> there is also a third problem with this tolerance but that doesn't cause
> anything wrong I think after twisting it around many times. But the use
> of tolerance in the macros in the begining of lilwgeom.h that looks like
> this
> #define FP_TOLERANCE 1e-12
> #define FP_LT(A, B) (((A) + FP_TOLERANCE) < (B))
> #define FP_LTEQ(A, B) (((A) - FP_TOLERANCE) <= (B))
> #define FP_CONTAINS_BOTTOM(A, X, B) (FP_LTEQ(A, X) && FP_LT(X, B))
>  makes no difference in the result in any case. It causes only a small
> shift in the whole calculation. If it would have made any difference I am
> quite sure it would also have been one or many cases where the tolerance
> would have caused wrong answer. But now I think it is only confusing.
> The last issue I would like to just remove the tolerance part, but I
> suspect it is there for some reason. Does anyone remember? the regression
> tests passes on my computer if I remove it.
> The two first problems is worse. I guess we need some sort of tolerance
> to be sure to catch the boundary-cases. But this is not the right way, I
> think I have found. Both because it gives an unpredictable tolerance as
> shown in 1) and second because there is no tolerance at all in vertical
> and horizontal segments.
> I attach an image showing the point and polygon from #845 to illustrate.
> The distance betwen the point and the left boundary is about 3e-7 m.
> /Nicklas
New description:
 I have taken a closer look at function point_in_ring because of my task in
 #846.
 select st_intersects('POINT(0.5 0.5000000000001)'::geometry, 'POLYGON((0
 0, 10 10, 1 0, 0 0))'::geometry);
 select st_intersects('POINT(0.5 0.500000000001)'::geometry, 'POLYGON((0 0,
 2) the second problem is the construct to first check on which side of the
 segment the point is with a tolerance and then deciding if the point is
 within the endpoints without a tolerance. The second test will make the
 anything wrong I think after twisting it around many times. But the use of
 tolerance in the macros in the begining of lilwgeom.h that looks like this
 The two first problems is worse. I guess we need some sort of tolerance to
 /Nicklas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/852#comment:1>
