[postgis-devel] [PostGIS] #762: [raster] Raster some check fails
trac at osgeo.org
Wed Mar 9 13:42:20 PST 2011
Reporter: aperi2007 | Owner: pracine
Type: defect | Status: assigned
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by strk):
I'm gettin failures too, with r6888
I guess the lack of a pre-install check is making these tests kind of
ineffective.
rt_addband. failed (diff expected obtained:
/tmp/rtpgis_reg_24868/test_8_diff)
rt_overlap. failed (diff expected obtained:
/tmp/rtpgis_reg_24868/test_35_diff)
rt_spatial_relationship. failed (diff expected obtained:
/tmp/rtpgis_reg_24868/test_40_diff)
Run tests: 41
Failed: 17
about to attach rtpgis_reg_24868
Ticket URL: <http://trac.osgeo.org/postgis/ticket/762#comment:7>
