[postgis-devel] [PostGIS] #851: [raster] Numerous ST_Value query cause the memory to grow indefinitely
PostGIS trac at osgeo.org
Tue Mar 15 09:30:15 PDT 2011
 Reporter:  pracine         |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  critical        |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by pracine):
 No memory growing? Nothing? What if you test on a coverage composed of
 smaller tiles (10x10)? The memory should grow faster and higher.
 This memory growth might be acceptable on one srtm raster but it overflows
 on a coverage composed of many of those.
 This symptom is generalised to most functions. It is worst with ST_Value
 because when iterating over a raster you call it millions of time but the
 same problem would show up with most function if there are millions of
 tiles.
 I am pretty sure this is the same problem Etienne encountered here:
 http://postgis.refractions.net/pipermail/postgis-
 devel/2011-January/011505.html
 The test I did was to simplify RASTER_getPixelValue to the point where it
 just returns a constant, no ctx, nada and in this case there is no general
 memory growth. Every function should release any memory allocated and the
 memory use should be almost constant without growing constantly.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/851#comment:11>
