[postgis-devel] [PostGIS] #860: [raster] Modify ST_MapAlgebra to handle expressions and user-functions
trac at osgeo.org
Wed Mar 16 13:47:01 PDT 2011
Reporter: dzwarg | Owner: dzwarg
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
1. Modify ST_MapAlgebra to ST_MapAlgebraExp (with expression) to evaluate
cells of a raster with a single expression.
1. Create ST_MapAlgebraFct (with function) to evaluate cells of a raster
with a user-specified plpgsql function.
To support item 2, the rt_pg layer needs a hook from SQL to callback a
specified function. I am calling this '''ST_CallUserFn'''. This method
takes a callback plpgsql function that will be evaluated for every cell in
the raster.
A callback plpgsql function currently must be defined in the following
manner:
#!sql
CREATE OR REPLACE FUNCTION MyUserFunctionName(cell FLOAT, VARIADIC args
TEXT[])
RETURNS FLOAT
AS $$
DECLARE
-- Some custom arguments, always passed in as TEXT type.
arg1 FLOAT;
arg2 FLOAT;
BEGIN
-- To use your custom arguments, cast them to the type you need,
-- and perform your calculations. Return the new value for the
-- new raster cell's value.
RETURN cell;
END;
$$ LANGUAGE plpgsql;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/860>
