[postgis-devel] [PostGIS] #123: SQLite output format support for shp2pgsql
trac at osgeo.org
Thu Mar 17 10:56:21 PDT 2011
Reporter: schuyler.erle | Type: task
Status: closed | Priority: medium
Milestone: PostGIS Future | Component: postgis
Version: | Resolution: invalid
Keywords: |
Changes (by jadams):
* status: new => closed
* resolution: => invalid
Old description:
> Please find attached a patch that adds a -L option to shp2pgsql provide
> special-case data typing and string formatting for SQLite-compatible
> output.
> I have tested the output with SQLite 3.5.2 and it correctly creates and
> populates a table. The geometries are correctly stored as WKB in an
> SQLite
> BLOB column.
> Granted there are other ways to import spatial data into an SQLite table,
> but shp2pgsql is the fastest way that I've found to convert both
> Shapefiles
> *and* DBF files into SQL suitable for quick import into a database, which
> is very handy for piping to SQLite's in-memory databases.
New description:
output.
populates a table. The geometries are correctly stored as WKB in an SQLite
BLOB column.
Shapefiles
Comment:
Supporting other databases is a little outside the realm of a loader for
PostGIS, which is an extension for PostgreSQL.
I looked into having an option to generate pure SQL-99 output, using a
BLOB or similar, which at least would not be specific to a different
database. Unfortunately BLOB support varies among databases too much for
it to be useful (PostgreSQL doesn't use standard syntax, among others).
Closing as invalid.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/123#comment:4>
