[postgis-devel] [PostGIS] #861: DropGeometryTable should not raise exception if no geometry column
trac at osgeo.org
Thu Mar 17 13:05:19 PDT 2011
Reporter: aperi2007 | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Actually the DropGeometryTable raise an exception if the table has no
geometry column.
This patch avoid this exception.
So the
DropGeometryTable() drop always the table if there isn't object dependent
from it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/861>
