[postgis-devel] [PostGIS] #866: [raster] Change the ST_MapAlgebra nodatavalueexpr text parameter for nadatavaluerepl
trac at osgeo.org
Fri Mar 18 08:23:36 PDT 2011
nadatavaluerepl
Reporter: pracine | Owner: pracine
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
The original plan to support refering to neighbour pixel in Mapalgebra was
to refer to them using their position relative to the pixel being compute.
e.g.: "rast[-1,0] + 1" rast[-1,0] refering to the first pixel at the left
of the pixel being computed. This prove to be hard to use when the desired
neighbour area include most pixels of an area larger than the first
neighbour.
The better alternative is to propose a variant to ST_MapAlgebra named
ST_MapAlgebraNgb which would pass a vector of value (or a small raster) to
a user defined summarizing function that would return the value to be
assigned to the pixel.
The original ST_MapAlgebra nodatavalueexpr text parameter was intented to
give a way to provide an alternative expression in case one pixel value
refered by the relative neighbour syntax (rast[-1,0]) would be nodata.
Since this syntax will not be offered/implemented there is no more need
for a nodatavalueexpr, a more simple nodatavaluereplacement value is
sufficient.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/866>
