[postgis-devel] [PostGIS] #229: shp2pgsql ability to transform from one spatial ref to another
trac at osgeo.org
Fri Mar 18 08:41:19 PDT 2011
Reporter: robe | Owner: jadams
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS Future
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Changes (by jadams):
* status: new => closed
* resolution: => fixed
Comment:
Resolved in trunk in revision 6922.
The new parameter is -r <srid>, the srid to reproject from. -s is the
srid to reproject to, unless you use -G in which case 4326 is the srid to
reproject to. So the combination of -G and -r will allow you to go
directly from a state plane shapefile to a geography table.
-r does not work with -D.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/229#comment:7>
