[postgis-devel] [PostGIS] #748: shp2pgsql use wrong schema name
PostGIS trac at osgeo.org
Fri Mar 18 12:49:06 PDT 2011
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by robe):
 Jeff,
 Okay the regress tests are now working and failed as expected at your
 schema check test.
 Unfortunately the patch you have above didn't seem to make it work.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/748#comment:25>
