[postgis-devel] [PostGIS] #808: shp2pgsql and encoding, something must be wrong
trac at osgeo.org
Fri Mar 18 13:20:55 PDT 2011
Reporter: nicklas | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Comment(by robe):
On MingW the regress is failing -- here is the output of the diff
--- loader/Latin1.select.expected Fri Mar 18 16:06:43 2011
+++ /tmp/pgis_reg_5684/test_22_out Fri Mar 18 16:13:07 2011
@@ -1 +1 @@
-1|Tårneby in Våler I Solør kommune
+1|Tårneby in Våler I Solør kommune
Ticket URL: <http://trac.osgeo.org/postgis/ticket/808#comment:12>
