[postgis-devel] [PostGIS] #808: shp2pgsql and encoding, something must be wrong
trac at osgeo.org
Fri Mar 18 14:35:58 PDT 2011
Reporter: nicklas | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Comment(by jadams):
Interesting. What did you do to the expected file, just set the encoding
to latin1? Via svn:propset or what?
I'm not sure if MinGW has the "od" command, but if it does could you run
it on both files?
od <expected>
od <_out>
Ticket URL: <http://trac.osgeo.org/postgis/ticket/808#comment:18>
