[postgis-devel] [PostGIS] #748: shp2pgsql use wrong schema name
trac at osgeo.org
Fri Mar 18 13:59:29 PDT 2011
Reporter: aperi2007 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
Okay the test is fine, it really is failing. If I put back in Mark's hack
the test passes. So I guess since it fails on the load, it never gets to
the part of doing an expected output. Though the load.err file gets
overwritten with the Latin issue so is useless for diagnosing.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/748#comment:31>
