[postgis-devel] [PostGIS] #808: shp2pgsql and encoding, something must be wrong
PostGIS trac at osgeo.org
Fri Mar 18 13:36:56 PDT 2011
  Reporter:  nicklas  |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Comment(by jadams):
 I believe you're correct.  I think the file you're getting out of SVN is
 somehow different from the one I checked in, probably because SVN is doing
 some encoding translation wrong.  You can set encodings in SVN, I'll need
 to figure out what it should be set to.  Either that or try marking it as
 a binary file so nothing gets translated.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/808#comment:14>
