[postgis-devel] what version of geos ?
aperi2007
aperi2007 at gmail.com
Sat Mar 19 09:55:20 PDT 2011
>It should be circa 3/8/2011 version forgot the exact r#. Are you having
>problems. If you are I can recompile and replace with that.
I not tested again.
But if it is about 03/08 I guess there is no problem.
I need the
GEOSRelateBoundaryNodeRule
that was applied in the 03/04
http://lists.osgeo.org/pipermail/geos-commits/2011-March/001240.html
Regards,
Andrea.
