[postgis-devel] What to return when refering to an invalid bandnumber
Paragon Corporation
lr at pcorp.us
Fri Mar 25 10:26:06 PDT 2011
>I tend to disagree.
> Out of range values are unknown, and as such should be threated.
> For example:
> =# select substring('test' from 10 for 1); substring
> (1 row)
> --strk;
I agree with Sandro about out of range. If you get a NULL, I think its
pretty clear and accepted that means unknown and better yet is easy to
filter out in a batch query.
An example case where this might happen and I really don't give a damn, is
if I do a generate series call to pull out the first n row/col values of a
raster. If I slide off the raster, I would just want NULL and then filter
it out in my where clause.
