[postgis-devel] [PostGIS] #885: pgsql2shp fields conversion from predefined list
PostGIS trac at osgeo.org
Sat Mar 26 16:27:35 PDT 2011
 Reporter:  rodo         |       Owner:  loic
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 1.5.3
Component:  postgis      |     Version:  1.5.X
 Keywords:               |
Comment(by loic):
 Here is a tentative patch against 1.5, which does not even compile yet.
 And I'm still unsure where the unit tests should be written.
 --- pgsql2shp.c.~1~     2011-03-26 17:41:44.000000000 +0100
 +++ pgsql2shp.c 2011-03-27 00:19:35.700567533 +0100
 @@ -65,6 +65,8 @@
  int rowbuflen;
  char temptablename[256];
  char *geo_col_name, *table, *shp_file, *schema, *usrquery;
 +char **geo_map = 0;
 +int geo_map_size = 0;
  int type_ary[256];
  char *main_scan_query;
  DBFHandle dbf;
 @@ -1258,6 +1260,52 @@
         return 0;
 +#include <sys/stat.h>
 +void
 +read_geo_map(char* file)
 +#if 0
 +  struct stat stat_buf;
 +  static char* content = 0;
 +    FILE* fp = 0;
 +    if(stat(file, &stat_buf) < 0) {
 +      perror(file);
 +      return;
 +    content = malloc(stat_buf.st_size);
 +    fp = fopen(file, 'r');
 +    if(stat_buf.st_size != fread(content, stat_buf.st_size, 1, fp)) {
 +      free(content);
 +      fprintf(stderr, "fread did not return the expected amount of
 chars");
 +    fclose(fp);
 +    int i;
 +    geo_map_size = 0;
 +    for(i = 0; i < stat_buf.st_size; i++) {
 +      if(content[i] == '\n') {
 +       geo_map_size++;
 +    geo_map = (char**)malloc(sizeof(char*)*geo_map_size);
 +      char** map = geo_map;
 +      *map++ = content;
 +       if(content[i] == '\n' && i + 1 < stat_buf.st_size)
 +         *map++ = content + 1;
 +       if(content[i] == '\n' || content[i] == ' ')
 +         content[i] = '\0';
 +#endif
  void
  usage(char* me, int status, FILE* out)
 @@ -1299,7 +1347,7 @@
         memset(buf, 0, 2048); /* just in case... */
         /* Parse command line */
 -       while ((c = pgis_getopt(ARGC, ARGV, "bf:h:du:p:P:g:rk")) != EOF)
 +       while ((c = pgis_getopt(ARGC, ARGV, "bf:h:du:p:P:g:rkm:")) != EOF)
                 switch (c)
 @@ -1332,6 +1380,9 @@
                 case 'g':
                         geo_col_name = pgis_optarg;
                         break;
 +               case 'm':
 +                   read_geo_map(pgis_optarg);
 +                       break;
                 case 'k':
                         keep_fieldname_case = 1;
                         break;
 @@ -1594,9 +1645,19 @@
                  * becomes __xmin when escaped
 -               /* Limit dbf field name to 10-digits */
 -               strncpy(field_name, ptr, 10);
 -               field_name[10] = 0;
 +               if(geo_map) {
 +                 int i;
 +                 for(i=0; i<geo_map_size; i++) {
 +                   if(!strcasecmp(geo_map, ptr)) {
 +                     /* the replacement follows the terminating null */
 +                     strcpy(field_name, geo_map + strlen(geo_map) + 1);
 +               } else {
 +                 /* Limit dbf field name to 10-digits */
 +                 strncpy(field_name, ptr, 10);
 +                 field_name[10] = 0;
                  * make sure the fields all have unique names,
Ticket URL: <http://trac.osgeo.org/postgis/ticket/885#comment:3>
