[postgis-devel] [PostGIS] #889: shp2pgsql fail load localized character
trac at osgeo.org
Sun Mar 27 02:32:54 PDT 2011
Reporter: aperi2007 | Owner:
Type: defect | Status: new
Priority: high | Milestone: PostGIS 2.0.0
Component: management | Version: trunk
Keywords: |
using the
experimental version for windows:
POSTGIS="2.0.0SVN" GEOS="3.3.0-CAPI-1.7.0" PROJ="Rel. 4.6.1, 21 August
2008" LIBXML="2.7.6" USE_STATS
the shp2pgsql.exe don't load this shapefile where there is this local
characters: "àèìòù".
I try with this settings:
SRID:3003
Encoding "UTF-8"
I verify that removing the localized character the shapefile is correctly
loaded.
Even on Linux debian version of Linux this shapefile with localized
character isn't load.
I attach to this ticket the shapefile.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/889>
