[postgis-devel] [PostGIS] #889: shp2pgsql fail load localized	character
    trac at osgeo.org
    Sun Mar 27 06:26:02 PDT 2011
  Reporter:  aperi2007   |       Owner:
      Type:  defect      |      Status:  closed
  Priority:  high        |   Milestone:  PostGIS 2.0.0
 Component:  management  |     Version:  trunk
Resolution:  invalid     |    Keywords:
Changes (by strk):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 While UTF8 is a possibly multi-byte encoding, Latin1 (like others) are
 single byte.
 For single-byte encodings there's no way to tell if the encoding is
 correct, as each byte correspond to a character, so at worst you get wrong
 character.
 For multi-byte, there can be _wrong_ sequences.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/889#comment:3>
