[postgis-devel] [PostGIS] #885: pgsql2shp fields conversion from predefined list
trac at osgeo.org
Sun Mar 27 09:14:45 PDT 2011
Reporter: rodo | Owner: loic
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Changes (by loic):
* status: new => closed
* version: 1.5.X => trunk
* resolution: => fixed
* milestone: PostGIS 1.5.3 => PostGIS 2.0.0
Comment:
The proposed patch ( attachment:885-trunk.patch ) implements the feature
against changeset:6970 . The corresponding tests can be run with:
./configure --with-gui
make check
make -C loader/cunit check
Note that {{{--with-gui}}} and the need to explicitly ask for running the
tests in the {{{loader/cunit}}} are not a behaviour added by the patch.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/885#comment:5>
